M4 Aqua Touch Problem
MJ92
I just recently bought this phone, and the thing thats going on my nerves is that it has touch problems. Touch lags sometimes, it freezes, and presses random stuff on screen.  Any solution to this problem? Thanks
8 REPLIES 8
@MJ92
Does your phone has a protective case and/or film?
does it has glove mode on?
Phy
Legend
Legend
Do you experience the same while on safe mode?
How to boot on safe mode
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
MJ92
It has protective case, no film, nothing on screen and the glove mode is off. This happens around 10 times pre day in every app, it even sometimes has problem with moving icons almost always or drawing the pattern lock...
Christofer
Hi @MJ92,
I'm sorry to hear this.
How does the touch work if you test it in Diagnostics?
You can find Diagnotics if you go to Settings > About phone > Diagnotics.
MJ92
Well it works well, it passed test. I run phone in safe mode, but problem still happens.
Christofer
In that case I suggest that you perform a software repair using PC Companion of your phone.
MJ92
I have tryed software repair, it didnt help. Any other suggestion?
Christofer
I then suggest that you see if you can have your phone examined at one our authorised service centers. Contact your Local support for more information.
