Hi anindita316,
Welcome to the community,
Generally this happens when an app is running in the background which is consuming more battery then what the charger can supply.
You would be best to power off the device and then start the charge process, turn the device back on after around 30 seconds.
Hi jake, thank you for the advice. My phone shuts down by now and is on a charging process. I've tried what you said, but it kept wont turning on. Does it have to do with something else, like maybe my charger is broken or the electricity's no strong enough?
This can be a possibility, you may try another cable, charger or plug and see if it makes any difference.
Are you saying that the device is not turning on now? or do you mean that there is still no charge?
