@Hc221,
I am sorry to hear that.
Could you try rebooting your device to safe mode and then try to see if the same occurs? Aside from that, I would suggest a software repair using Xperia Companion in case it behaves the same way in safe mode.
If a software repair does not resolve it, then it's likely hardware related and in that case I recommend that you contact your Local support in order to have your device sent in to service.
Thanks for the suggestions, I'll have a look into these and see if they work. If not, I suppose there's no hardship in just getting some more new earphones with a handsfree mic accessory.
