Hello,
I am thimking of using a Xperia M dual in Japan but I am confused about the phone ability to handle the networks here.
I want to use 1 SIM for voice+SMS only and another SIM for data only. Normally that wouldn't be a problem but Japan doesn't have GSM networks so even my voice SIM would need to connect to a W-CDMA (3G) network.
How will the phone handle that?
I am ok if I can't use both SIMs at the same time but will standby work on both SIMs at the same time?
Any info appreciated.
Dual standby means only one SIM can work at a time,one can go on WCDMA and the other on GSM only.
Thank you for your answer but it is still not clear for me.
I know that only 1 SIM at a time can be active. My question is about standby. Is it possible to have both SIM in standby on WCDMA at the same time? Or is having 1 SIM in standby on WCDMA forces the other to be GSM only?
No,only one can be on WCDMA at a time.The other must be on GSM only.And you should set the first SIM to WCDMA.
Okay then, too bad.
Thank you for your help
Anytime.
