I am facing an issue with the touch screen on the Live, when I type the letter A it usually comes up with Q, this is very annoying when browsing/texting. This happens very often and is not fixed by re-installing the firmware-it has happened on the ICS firmwares (.431 & .587) and Gingerbread (.62). I have no other problems with the Live's touch screen, so is there can fix/calibration setting that I can use?
I used to have the same problem. But it corrected itself automatically. I mean now the problem is solved.
Just wait a little more and see.
i also have problem with sony ericsson live wt19, my touch screen, before it was smooth and responsive but suddenly it became unresponsive, its still working but not as resposive as before. for ex. if you will type 1 to 10, it will end up missing numbers like 1 2, 6 8,10, thats why when texting it always missing some words.. anyone can help me, somebody told me that it is about calibration but i dont know how to calibrate..
have you tried re-updating using Sony Update service?
Yes I have tried re-installing the firmware(s) via SEUS and PCC, although most of the times I use PCC (I have re-installed the stock ROMs many times). In addition I also have flashed the stock ROM's via Flashtool. None of them fix the issue.
Ok. I have only been using the .62 GB firmware for a week because before that I used ICS .587 which was a huge let down in terms of performance (it reminded me of my previous slow experience with the X8). I hope your right.
