LTE and fallback
balloonix
LTE and fallback
Even if the Phone makes a fallback from LTE to 3G or 2G the Data transmission Stops. There is only one way to get in back: Shut down and restart the phone again.
Tags (1)
3 REPLIES 3
ashishsingh007
If the fall back network has very nice coverage, I don't think again go to higher as one will be using it. However when you have issue with coverage in 3G and lte has better network it will definitely go to lte. That's what I have observed
As stated above it will go to anything that has better coverage / stable, lte to 3G if not stable then 2G
Crackles
I have found the same with my Xperia Z2. If I set it on LTE and it finds 4G then it won't Fallback to 3G for Data...it just sits there with the Signal Strength (i am assuming it is 3G Signal) until I perform a Restart.
We are now utilising what Telstra call 4GX which is at 700Mhz....I was assuming this may be the issue as it may not be fully developed as yet even though Telstra say it should roam over to 4GX seamlessly.
