LT18i erratic screen issue
Pratna
Folks, I am unable to use my phone itself now. The screen behaves erratically. It's so random that I am even afraid of writing anything to anyone. For example if I try to select a particular whatsapp message to forward to someone, it may decide to select another one and then I will be unable to scroll to the whatsapp group I want to send to. Similar thing happens when I want to text. It will put random letters and even while pressing backspace to delete, suddenly it will send it as well. Pls advice
3 REPLIES 3
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Pratna
Thanks. But didn't help as I forgot to mention one more sysmptom. Earlier, i.e. if I try and squeeze or twist or squeesh the phone, the display used to become brighter and worked perfectly. However this trick not helping me now for the last 1 month. To my mind seems like some loose connection somewhere which used to fall in line while being twisted.
Any pointers now?
Cheers
_alexdon_
You should have the device checked at a sony service:
alexdon
