Hi
I am having trouble with the call volume when using the louspeaker.
Seems to only use 1 of the 2 speakers?
I have tweaked the all the setting including the equalizer which has improved the head phone volume but had no effect on the loudspeaker. When talking normaly the volume is ok but could also be louder
does anyone have any ideas
thanks
I am also facing same issue. too much low volume when using loud speak any help will be great.
its removing the satisfaction of having best phone z3 compact with a defect of low volume when using speaker while in car.
Any patch or update without losing the data will be great
Sorry to hear that you have issues with the volume.
This has been forwarded internally as feedback and the information i have is that there will be improvements in the next software update.
The phone will however only use one speaker when you use it as a speaker phone to avoid echo.
Hi All,
Does anyone else have the issue where putting a phone call onto the loudspeaker results in only marginally better volume that having the call in standard mode?
When watching a video etc, putting the speakers up to max is acceptably loud. I do not find I get the same volume when a call is on the loudspeaker.
Cheers,
Z3 Compact is quite with call voice loud speaker, not understad well in noisy background. With another phones I not had this issue. This is one of main features what people use, phone testers not did good job.
Can you tell which specific version is that to be rolled out? Is this fix included in 23.0.1.A.5.77 ?
Looks like Sony are just sitting this one out, waiting for us to stop complaining. Poor loudspeaker function is not a deal-breaker to a lot of people, also the Z3C is now getting old enough for them to effectively ignore it, the early adopters wil move onto another phone soon, everyone else who gets one probably isn't the sort of user that will complain.
Sony ignores the problem, and wins again.
My z3 compact has developed the same problem. Not 6 weeks old and all calls must be taken with the external speaker on. Too quite otherwise. I signed up here hoping to find a solution before sending the phone back. Not possible now to make a private call. Phone has been in a case from new. It did work well enough but not loud but now very disappointed.
