loudspeaker_problem Xperia Tipo
nawindara
Am unanle to hear the songs with loudspeakers in phone even ring tones also not able to hear.
but when it connects the headset its i can hear through headset. Any one help me in this issue.
Regards
Naveen.D
2 REPLIES 2
Ironman
I experienced this to my xperiaZ. After having a call from Viber, then this problem occurs, it seems that the audio is being used by Viber Application. But if you manually close the Viber application, then the loudspeaker is being normalized again. I hope Sony can fix this issue on the next update.
Alexander1
Try to remove the headset while music is playing. Restart your phone and remove the battery for a while.
If the problem persists you can try to update/repair the phone software to rule out any software problems:
