Loudspeaker not working
deemah
Frnds my phone loudspeaker not working suddenly.I already encountered the same issue, but when u plug in and plug out it will work normal.i also resetted and repaired software using pcc,but this time i tried all the mentioned options above nothing works till now(already one week gone).need some useful ans please...please
12 REPLIES 12
profile.country.RO.title
_alexdon_
If a software repair didn't help,you should stop by a sony service.
alexdon
deemah
I already did,they are saying speaker works fine and this might be a software bug....what the **bleep**?????
_alexdon_
They have excluded any hardware problem?
alexdon
deemah
I just wanted to know whether its a common software bug or else im the only one who is facing this kibd of issues.
_alexdon_
Wait until some others post then.
alexdon
mklaasse
I experienced this phenomenon about three times now. It got me puzzled.
I found out that connecting and disconnecting headphones solved the issue.
It looks like the phone did not realise my headphones was disconnected. Therefore there was no audio output to the speaker.
You might try connecting and than disconnecting the headphones. If this does not work directly you can reboot your phone and then perform the connecting/disconnecting.
_alexdon_
It seems that sometimes the phone stays in headphone mode or vice versa.Sometimes,disconnecting the headset while listening to music or while in a call sorts it out.
alexdon
dg26
I also have the loudspeaker problem, I replaced the speaker and the problem is still there.
samrocks
This problem exists in almost every xperia sp...
At first it happened to me but after regular headphone usage it's working fine now..
