Hi guys. Yesterday my xperia is stop in bootanimation. I try restore rom with PC compation , Flashtool, Emma but nothing, always stop in bootanimation. I unlock my bootloader for flash recovery but I did not succeed to get it started. I don't know what to do. The smatphone run in fastboot and in flashmode.
I already tried it with both flashtool that with emma. Both with KK that with JB. The operation is successful, no problem but i have always loop in bootanimation
I dare say that you could have damaged the coding with the failed attempt at flashing the recovery - The kernal is loading but then when the rest of the firmware is trying to load it simply can't
Not sure - I suppose a last option is to find a pre rooted img file for your device if there is one on XDA or anywhere else and use Fastboot to flash the image - Not to be confused with Flashmode like Emma or Flashtool and also Pc Companion
@Thommo wrote:Not sure - I suppose a last option is to find a pre rooted img file for your device if there is one on XDA or anywhere else and use Fastboot to flash the image - Not to be confused with Flashmode like Emma or Flashtool and also Pc Companion
i don't find anything unfortunately
I try with aosp lollipop but nothing always loop bootanimation
Sorry I'm out of ideas but I still revert back to my 1st post of a partition been deleted which holds code that determines how a device boots up
Thanks Thommo. I think I'll have to resign
