Lollipop UI Bugs [Russian localization]
MetalMedved
Phone UI changes since lollipop update so some bugs appears.
1. WI-FI and Bluetooth icons can't be removed from notification panel like before. Also new profile avatar can't be removed as well. This features should be optional
2. If I turn off top cantacts service then its empty panel still exists above call list. It should have ability to turn top contacts panel off
3. Calculator has only 'delete' button. It should have regular C/AC buttons because it's not a notepad
4. Terrible 'Close all' button in task list. Can it have equal bevels on all sides?
Thanks
Tags (3)
3 REPLIES 3
MetalMedved
1. Add music player operability to ultra stamina mode. I know it works with headset so please make it available natively. Fm radio is not enough.
2. Auto rotate quick option. It doesn't lock screen rotation. It always set phone to portrait rotation. Please make feature to lock screen rotation in current orientation. Like I play video in album orientation turn off auto rotate and screen hold album mode.
Rickard
Thanks for your feedback!
These are not bugs in the firmware but how it's designed to look and work but i will of course forward your feedback internally.
Regarding the calculator you can tap and hold DEL to clear all.
If you want to lock the screen at a certain rotation there are apps that can do this for you like https://play.google.com/store/apps/details?id=com.googlecode.eyesfree.setorientation
ytheekshana
Hi It Seems like Icons in Lollipop is Too Big. Now whole the screen is filled with Big icons
