- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Lollipop charging problems with docking
Last week I upgraded to Lollipop and I made a factory reset to use a fresh and smooth installation but I noticed a bug when I charging the phone with the docking it only charge at 75 percent then the phone start to show the screen thats connect and disconnect by it self when it reach this percent
When I plugged it to the usb port I don't have this problems and it charge at 100% before the upgrade to Lollipop and haven't seen this problem.
Is this a docking bug with Lollipop? Anyone have this symptoms?
Thanks for your help.
Rafael.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Restart your phone and check again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I suggest you try to charge the device for 1-2 weeks directly to the main plug. Avoid magnetic chargers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the exact same issue, stuck at 75%, the red charging led flickers and it won't fully charge. Any other suggestions?
The purpose of using the dock is to avoid removing the flaps as they seem pretty weak. Please advise.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem too but mine is stuck at 89%
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@razucena wrote:Hi,
Rafael.
Looks like I have the same problem (see "main" Lollipop thread), but I did not think it was related to the dock. Apparently it is. After using the dock, did you notice problems detecting the battery level ? Mine remained stuck at 75% and the history graph was empty for several days (except for detection spikes after each restart of the phone), until I plugged it into my PC (I was about to do a reset and reinstall).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It seems it all happened after we upgraded to lollipop and it's becoming annoying. I am not comfortable by charging the phone via USB.
Any suggestions? Hopefully this gets fixed with some updates.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sorry to hear that you have issues with charging.
If you are unable to charge above a certain percentage (seems like a bad connection with the charger when it reaches a certain level) then this is something that we're currently investigating. Please follow this thread if you have this issue: http://talk.sonymobile.com/t5/Xperia-Z2/Lollipop-c
