Lolipop relates fixes
Chinmay
Sony please fix these problems in Marshmallow Update
1. Change the whole ui of the camera app. This is the worst thing. You'll are restricting Xperia z2 camera performance.
2. Frames shutter in some apps.
3. While enabling Ultra stamina there are lots of problems. Animation problems etc
4. Improve volume control and audio related things.
5. Image enhancement always gets off after some days automatically.
6. Bring back Bluetooth Unlock which was there in android 4.4.4. I can't use my SmartBand to unlock my device. It uses NFC unlock which is bad. BLUETOOTH UNLOCK WAS THE BEST.
7. Improve overall performance of the phone. The phone still sometimes lags or stops responding in some cases.
8. Bring some changes in Marshmallow Update. Don't keep it the same as lollipop.
Hope Marshmallow comes to Xperia Z2 quickly as fast as possible ☺
2 REPLIES 2
profile.country.US.title
Qatrium
@Chinmay
It's a good idea if you also forward your feedback/suggestions to your Local support. I'll give my opinion on some of your points:
1. There's a new interface presented in Z5, dunno if it will be extended to Z2 on Marshmallow.
2. If your phone is beginning to lag, consider performing a software repair using PC Companion after a back up of your data.
3. That's how Ultra Stamina mode is supposed to work, it will throttle performance and CPU usage to extend battery life.
4. There's a new way to control volume and audio in Marshmallow, what's your exact problem with volume control now?
5. Image enhancement will go off when using Ultra stamina mode.
6. You can unlock with bluetooth in Settings -> Security -> Smart unlock
7. Same as 2
8. What changes exactly? Give some suggestions. Personally I use Sony mainly because I like the UI the most.
Chinmay
@Quester Thanks for this urgent reply
The Bluetooth Unlock is good but SmartBand SWR10 is recognized as an NFC device and not Bluetooth. In 4.4.4 it was recognized as a Bluetooth device. Currently I need to tap my phone on the SmartBand to unlock it, but before my phone used to get Unlocked even if my SmartBand was near it. The basic problem is that SMARTBAND SWR10 is not treated as a Bluetooth device.
In case of volume control there are bugs, when I use the volume rocker switch sometimes there is a bit delay in the sound output.
The virtual home button,etc all must be made more smaller ... They are very big. This will make the usable screen size more big.
I personally liked z5's user interface. It must be to Z2 on Marshmallow.
There is also one small bug.. The notifications do not extended, when extended by two fingers they extended and again become small. This has started from last update of Z2.
eg. If I get a missed call and then I have to redial that number, there must be a call back button on that notification. But when is pull out the notification the button is visible and it again shrinks. Sony must fix it☺
Thanks
