locked x10
locked x10
How can I unlock my x10
8 REPLIES 8
suze
Leader
Do you mean the pattern lock, as in you have put in the wrong pattern too many times.  Or do you mean unlocking the phone from a particular network?
I have put in the pattern wrongly too many time and now I am required to sign with a gmail email address that I do not have. I also tried registering a new gmail account and I am still unable to unlock the phone
suze
Leader
As you don't have a gmail account your only option is to repair the phone on Sony Ericsson Update Service.  This will reset the phone and you will lose all your data so I hope you have your contacts backed up to your SD card or via SE sync.  The phones require you to have a google account so when you get it up and running for the first time I suggest that you enter one at that point.  Also if its not a default setting by your carrier then don't use the pattern lock, its a pain in the rear!  Just search on pattern lock on this site and see how many threads come up where people are locked out and have to do the reset.
Hope this helps.
I am unable to repair because my phone with not conect to my computer
suze
Leader
This seems to be a bit of a problem and the only thing I can suggest is try another computer, use a friends or family member.  It works most of the time, unless your phone is totally bricked.
Hi, you can unlock your Xperia X10 using the unlock code. this unlock code is available at Wickedunlock. you can get the step by step instruction here to unlock your mobile...
are you aware that this thread was created more than a year ago?
Use the codes to unlock your mobile.
