Locked out :(
Lyanna
Locked out :(
Hi my son has the Xperia sp and has forgot the 4 digit code to unlock it please help
8 REPLIES 8
profile.country.RO.title
_alexdon_
Unlock code for the SIM or unlock code for the phone?If it is for the phone,connect with SUS and repair.
alexdon
Jake-SonyXperia
Please use the link below to download PC Companion and perform a repair to remove the lock.
http://www.sonymobile.com/global-en/tools/pc-companion/
To repair the phone software
1.     Install PC Companion on a Windows PC from Support
2.     In PC Companion, under Support Zone and click Start.
3.     Under Phone Software Update, click Start.
4.     Click repair phone.
5.     Follow the on-screen instructions.
Surreylad
Same problem here.  I set a 4 digit pin to lock my new Xperia SP and it now won't accept the pin.  It is definitely the one I set but it has locked me out.  I tried the approach highlighted above but the PC Companion will not recognise the phone unless it is unlocked.  Any other ideas?
_alexdon_
Sony update service,repair and remove the lock.
alexdon
Latte
Did you try with Pc Companion or Sony Update Services? Or just tried with Pc companion?
Surreylad
I downloaded SUS but Xperia Sp was not one of the listed handsets in the menu for support?
Surreylad
Thanks so much guys.  I found elsewhere on the forum that the reason that the Xperia SP wasn't showing in SUS was a Windows 8 issue.  I found an older laptop running Windows 7, installed SUS and reinstalled the software as a repair, now I can get access to the handset.  Thankfully I had already backed it up.
_alexdon_
Good thing you did there,glad you are ok.You could have run sus in compatibility mode for W7.
alexdon
