My problem is as follows: My lockscreen widgets are inaccessible. This is because whenever I touch one, the android asks me, as usual, to unlock the screen in order to access it by sliding up or down (when using "blindfolds" or swipe lock mode), only that however I slide my finger on the screen, nothing happens, the unlocking blidnfolds animation doesn't work and, obviously, it won't unlock either. The tablet unlocks fine when I just need to unlock it to access my tablet, but the problem only occurs when trying to access a lockscreen widget driectly (such as clock, mail, or anything).
However, when I'm using a different lockscreen option, such as pattern for instance, it works just fine, but besides the fact that I don't want to use pattern, the lockscreen widgets should be accessible through whichever unlock type I use.
This is obviously a bug, and probably not a general one, so I'd like to know if anyone has it and if there's a solution for this.
A reply from a SonyCare agent would be most appreciated.
