Been reading a lot of this - seems like this feature on the stock 4.2.2 build 243 is not there.
Is there a way to have the notifications such as sms, missed calls etc on the lockscreen itself. JB is supposed to have the notificaitons available from the pull down. But when the screen is locked, the pull down donesnt work either..
Any way of doign this without loading other apps like widget locker etc??
I use an app called DashClock. It also has extensions which can also be found in the Play Store. DashClock gives you options like Weather, Battery, Missed Calls, Text Messages and more. Its also free.
pull down works fine in android 4.2.2 for me since i have been able to pull down the notify bar above in locked screen
here is a picture of it.
how do you pull down the notification from lockscreen? i'm also on 4.2.2 the pull down notification doesnt work unless i unlock the screen.. please let me know how you did it..also i cant see the picture...
I get no notification when in receive an sms _ no sound or notification in status bar..the only way I could see the new text message is when I open the messaging app..
All the notification settings are set to have tone.
What can I do? I tested it with go sms and I get notifications..but I like the default messaging app of ZL..
Please help
Just double check
Messanging app > menu > settings > notifications MUST be selected
All the notification settings are set to have ringtone. (both in general settings and in messaging app)
Please help
@vhl71 one thread its more than enough.
Solved...called sony support and they told me to do the software repair..that has solved the issue..
Excellent
