Lock Screen Camera Faulty
Katherine1
Screenshot_2013-11-04-19-53-40[1].pngHi all,
I purchased a Z very recently and its been great until I discovered a black block covering 1/4 of the main camera screen at the bottom with the recording and camera button still visible. This area would usually be clear, showing part of the photo being taken. Also, when I attempt to switch the the front camera, the screen jumps right back on to the lock screen.
This only happens when I access the camera through the lock screen; when I use the camera from the menu it is fine.
I have already tried turning my phone on and off twice but it has not worked, anyone have any ideas on how to fix this?
4 REPLIES 4
1. Seetings > apps > all > camera > clear cache > restart your phone and try again
2. repair your phone with SUS or PCC (re-install the current update)
andyactive
You have changed the megapixels to 12 rather than 9. 9mp is 16:9 aspect ratio ( full screen). 12 is nearer to the ratio of standard 6x4 photos, so its the better mode to use. You also gain 3 more megapixels.
JakeSully
reason why you got that dot is a camera failure, i recived 3 dots my self on my xperia z but i had it sent to repair and they re-placed the camera part and since then dots are gone Slightly_smiling_Face
update nvm i miss read your message there xD thought you said you had black dot some where but you actually mean black box near buttons to right xD
