So did you disable stamina?
Can you check if the same occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
You could give it a try,see if the device doesn't have a hardware problem related to wifi.
