LiveView is not working
Hello all,
today I got my new LiveView watch. The first thing I wanted to do is to load it for 2 hours. So I have plugged in the AC adapter, but nothing happened. No lamp was blinking. So I pushed the left button for testing, but also nothing happened.
If I push the right button, the Sony logo will come and the Live View wants to connect for 3 seconds. After that the display goes off again. But for the 3 seconds I can see that it is loading.
So I plugged in the AC adapter for 2 hours. After that I tried again, but if I push the on-off button nothing happens. Pushing it for 15 seconds make no changes.
Do anyone have an idea what I can do?
8 REPLIES 8
I've had an issue almost like yours. The device wont turn on. I have contacted the sales company and asked if I could return it.
I managed to get it working, but after I trying to charge the same thing happened.
When charging, the indicator on the left button should show red (turns green when fully charged).
@hotphil
That is clear. But as you can read in my first post no lamp is blinking. I dont see any lamp in red or green.
I'd try a new charger/micro-USB lead. If still no indicator light, a full reset (is it hold down left button for +15 seconds?) and see if the indicator works. If not, I'd be getting it replaced.
My unit died like one day after i got it..
I was able to charge it (red led that turned green after some time) but i could not turn it on. Nothing happened.
Got a full refund.
same happend to me just reset it. then turnd it on. Slightly_smiling_Face
My device won't turn on after the initial charge. I've contacted the seller but no response yet. How did you get yours to work? I tried even pressing and holding for more than 15 seconds to reset it but still no use. It's dead as a brick!!! But whenever I connect the charger the LED glows red and then turns green after a while indicating the device is charged. Would save me a lot of hassle if I could turn it on.
kittu
how to reset
