hi,
my new live with walkman phone havind call divert problem.
calls are getting diverted while mobile is in unreachable network.
i tried to disable call forward while unreachable from call setting but its not working.
help me please.
Where are they diverting too? A number you pre-set for another divert action?
check your call settings...u must have enabled call forwarding option when not reachable...check status and disable it.
Actuly it is diverting to number which I preset. I tried to disable it but it is showing error.
And I do have another lww mobile on that this functions working smooth
Yes buddy .....i tried many times to disable it. But it is showing error.
Did u tried to use this sim in another phone and disable call forwarding, and then put it back in this LWW phone and see if the problem is resolved. I am saying this because call forwarding is enable at operator level and not at phone level...just a quess work...may help
If this doesn't help then I think factory reset is the only option, and if that also doesn't work then repairing thru PC Companian should be tried...but u will loose ur phone memory data (so backup ur contacts & msgs)...good luck
