Limited connectivity
amirashahirah
Hi I'm having a problem with my phone . It says limited connectivity when I tried to connect with my wifi . I've tried reset my phone but it's not working 😕 It says I'm connected but I can't get through the internet . My wifi at home is connected to all devices except for mine Slightly_frowning_Face
Johan
Begin by rebooting both your phone and router and check if you still get limited connectivity. If yes, check if you can edit the IP range for IP numbers to be distributed from the router, perhaps you need to increase that. If you do this and you still get limited connectivity check if you can update your router firmware.
