Learining client 2.1 wastes battery
silfiriel
Now I am satisfied with how my battery lasts (around 36 hours with the help of Juice Defender and Power Saver turned on)
however in power managment when I check what wastes the battery
something called Learning Client 2.1 wastes 25% of the battery, Waht is this and can I turne it off?
Phine is running on ICS
80 REPLIES 80
deemoowoor
I have the same problem. Problem is not limited to the process "eating" battery, but it seems to use way too much CPU time (which explains high battery use). This results in all other functions on my phone (XPERIA Go) to be awfully slow, almost unusable, especially when in battery saving mode.
Switching off this process from the "Applications" settings menu instantly improves the situation -- until this process is automatically restarted by the system.
This is clearly a software bug which severely limits device's functionality and must be fixed ASAP.
Is there any other way of reporting this issue to the technical staff? I'm pretty sure it's easily reproducible, as so many people using Go are experiencing it.
Snudi
Hello Sony Support,
i also have the same Problem on my Xperia Go after ICS Update! The Learning Client wastes my battery and there is no Solution that worked! So please inform the Technical Staff to fixe this bug!
SimonDK
To illustrate, here's my battery status from this morning. The two sleep apps has been active through the night, and still uses only half as much battery as LearningClient - which AFAWK should have been doing nothing....!Screenshot_2012-11-07-09-11-00 combsmll.png
pilatus7_gmail_
Hi!
I have the same battery-drain problem after updating Xperia Go to ICS. At the moment, Learning Client 2.1 takes 52% of battery, followed by screen with 24%.
Looks like a serious bug.
Yes, there is possible to root. But, why shoud I?
oecher
Is there any support?! Any help would be appreciated. Thanks!
NikharGupta
I am also facing this problem, the usage shows only 3s but it has used up 43% of the battery. How do i stop the same on my xperia go?
mk4y
Same here? Any fix SONY?
wwwmirj
I am also experiencing this problem. I also checked in a Xperia Sola (running ICS) that my brother is using and this 'Learning Client' do not show up in that phone. It's seems to be a unique problem for Xperia Go.
sirieix
Hi same issue for me since i upgrade my xperia go to ics,can not see in my acro s. I hope that sony can deliver a patch to ics to fix this issue asap as it doesn't make sense to loose 50% of my battery for a learning client when the applicatipn is running 30sec! Is it also area dedicated ? I'm leaving in singapore but when i went to france 2 weeks ago seems the process was not active . So please sony do something or at least provide a clear status and answer. Thanks
NikharGupta
I have got the solution. Please follow the below steps:
Go to
Settings>Developer options>scroll down to sub-heading"Apps">Uncheck "Don't keep activities"
Thats it !!! This solved the problem for me, now i do not see Learning Client eating up my battery anymore Slightly_smiling_Face
