key unlock for bootloader
maxfact
Hi i have a problem when require the key for unblock the bootloader.
In this page http://unlockbootloader.sonymobile.com/node/add/ubs-request?token=e23ae3b7c5e57756e5b5dcb3b650930e when i put the code imei  tells me it should be 14 numbers but my imei is 15 numbers.
I saw a discussion here in the forum where it says to remove the last number for my imei so I get the key but when I go to give the command
fastboot -i 0x0fce oem unlock
 I get this error
INFOUnlock phone requested
FAILED (remote: oem unlock failed!)
 I use  system opertion archlinux
I suppose failed because the key unlock is not its
Do you have any idea??
ases
