Keep it up Sony!
Keep it up Sony!
I'm from Malaysia,
I using xperia neo v
I have already read the other phone user say the ics good or bad,but most of the bad news almost same with me,
the good thing is the face unlock and some function,I know it will be a bit laggy or drain battery fast but I dont mind,
the bad thing is the screenshot function why lost?this is the feature of xperia neo v,that is the most function I love,another bad thing is I cant play those a lot of game that use swipe or what etc angry birds and temple run.it cannot function it properly
my conclusion is,hope Sony can solve this two problem,screenshot and game,I use this phone to play game most of the time,I dont care they say what camera not good or what.I believe sony so dont let me down,this two thing hope can be solve after a update in the following time,keep it up sony!=D
6 REPLIES 6
ply17410
Screenshot is just different key press.
Power + volume down
Maybe your games just need an updated version from the developer.
Good luck,
Bob H
Minneapolis, MN
USA
Nabeel
Did you format your sd card before installing ICS ?
If not then it is suggested to do the same, first format your sd card and reinstall your phone's software again using pc companion or SUS and see if it worked better than before
btw,fomating my sd card is not the way to solve it,the ics program is install inside my internal storage and not sd card.I have already knew the problem of my game,like angry birds need a finger to supporting the screen to play,temple run still cannot solve it,I heard the other say temple run haven support for ics yet.So can the problem can solve in the future?
Nabeel
Hi
i didn't say it unecessarily though Slightly_smiling_Face
Surf the forum, you will come to know the importance of doing the same Slightly_smiling_Face
Do you know Meta dat of ics and gb differe from each other ?
I don't know....so,you recommended me to format my sd card?then the internal storage need to format also or not?
AbhayK7221
Hi Laukaiwen,
  It is not necessary to format the memory card or a factory reset.
I dont know how, but it has surely helped me since i've been updating my Arc right from the 2.3.2 firmware.
And i have done a factory reset (including Erasing the SD card) everytime after i had updated my phone n everything was smoothened after then. (And i've always update to the official rom released by Sony and not any custom third party roms)
I must say that my friend who used a Samsung had no problems after an update but for Sony this method surely works.:smileyconfused::smileyshocked:
Now I am waiting to update to ICS which is yet to come to India, but im really scared as i've heard it has a lot of bugs (big ones specially) which are yet to be solved....
