hey all,
everyone who has updated to the latest JB Update recently, and are facing wi-fi connectivity issue, here's a solution
(worked on xperia S and SL)
its Simple, Manually assign an IP address.
follow these steps:
* Search for WLAN netwroks
* tap the name of the desired network
* type the password
* check the "show advanced setting" box
(now, you'll have more options if you scroll down)
* Under Proxy Settings
(None)
*IP Settings
STATIC (change it from dhcp to static)
now type the ip address of your network manually, along with gateway address.
Network Preface Lenght is just your Subnet Mask(24 for me)
DNS server 1 is always 8.8.8.8 (except if your network has its own dns)
no need for DNS server 2
*Click On Connect
your wi-fi will work instantly.
Post here if you still face problems connecting.
Regards,
Nitin
So there is no DHCP system ... I C ... thanks for ur topic
i even cannot turn on wifi modem or search any network its been hanged when i do this ,now you say search for network?!
that's not working... because when we turn the wifi on the phone can't find any wifi network and in when we're going to network menu it's gonna hang most of the times and in conclusion these solution not working but we're very thankful for your post...
After update JB Wi-Fi very poor signal strength. This picture I take in a room where router is fixed.
in the first step when i search for wlan i cant find it.. was using it without any issue till the update.. any idea how to find the network? is there any app which could be helpfull?
i try this 1 but the phone is stuck always when i open wifi settings so i can't save my work on it it's tell me settings not responding then save field 😕
I believe that there is another option.
Under Wifi Advanced settings you can disable the option "Avoid poor connections" (this will keep the connection with the router/hotspot even with a low signal):
I hope it can help those are able to find Wifi connections with low signal.
