Can i ask something...
after upgrading my xperia p ics to JB...my phone got a couple of hours before the home screen appears everytime i turn it on..so plss help me what im going to do?..
Can you please rephrase?because i kind of dont understand the problem.Is your screen turning on from time to time?
u r saying tat ur boot time to reach the home screen takes time right ???:smileyconfused: it is normal aft the first boot of each update :smileygrin: aft tat it should go fine ..
i min after i updating my phone to JB...after 1 day when i restarted it...it took so long to be opened it takes 4hrs before the homescreen appeared..and when my operators turn it on...it opened but the battery takes 14% then my operators said because it is lowbat but its imposible when i restarted it my batt got 75%...then after that it takes so long to be opened..
Improper installation may be the reason .. Repair ur device with PCC or SUS
how?..
If you still experience problem you could try to repair the phone software using PC Companion:
In PC Companion, click start under Support Zone > start under Update phone > select Repair phone (in blue text) > Do all this without having the phone connected to the PC.
Then follow the instructions given to you in the program.
