Hi, All! I have j10i Elm. Youtube is only viewable using 3g(Data) NOT WIFI, and I found some people having the same problem. Ho to fix this?
First make sure that "Allow local conn." is enabled under Settings -> Connectivity -> Streaming settings.
If that doesn't help your routers firewall probably doesn't support "RTSP". Try turning off the firewall in your router or open the ports 554 and 8554 in the firewall.
I've done the 1st suggestion. Still cannot connect.
I can connect to all app, browsers, even 3rd party app such as opera mini. why just youtube?
Please try my other suggestion as well. Streaming of video uses another protocol (RTSP). The firewall in some routers doesn't support this protocol and therefore blocks it.
Same here. I can watch youtube with 3g but cannot with wifi. I use TL-WR841N router. How to port in and disable router firewall?
I found the following guide for setting that router up for RTSP but i don't know if it's correct: http://portforward.com/english/routers/port_forwarding/TP-Link/TL-WR841N/RTSP.htm.
If the guide is not correct i would recommend that you contact TP-Link: http://www.tp-link.us/support/contact/?categoryid=530
I stil cannot play youtube in my j10i with my router. Yesterday, i try wifi tethering from my Samsung Galaxy Grand and I connect my j10i with the wifi. It can play youtube in opera mini.
