Issues with Oct 2015 update
johanscott
Can anyone help me, I'm having issues with my Sony Xperia M4 Aqua
I updated my phone last night (M4 Aqua) regarding the preloaded apps (http://gadgets.ndtv.com/mobiles/news/sony-xperia-m4-aqua-update-removes-few-preloaded-apps-to-save-s...) and it said it'd be done in 15 mins. I assumed it finished because it restarted my phone but it's been stuck at the load up screen for well over a few hours so I can't access anything. I've tried to hold the power button but it won't work. Tried to force shut down in (that button beside the memory card) but when I turn it back on, it still stays in the loaded spot.
I've tried to connect it to my computer but my computer won't even recognize it.
15 REPLIES 15
xperiaperson
When you say won't recognize it, do you mean it's showing up as unsupported/unrecognized hardware or the pc is not reacting to it at all?
If it's the first, try installing drivers again.
johanscott
PC not picking up the device at all. I'm not sure if it's stuck on the loading screen or not.
profile.country.US.title
Qatrium
You need to perform a software repair via PC Companion, you need your phone powered off and charged to do this. Sadly you'll lose any data on the internal memory after this procedure but you can't back up from a boot loop. Do not connect your phone to PC until you're prompted to do so.
Open PC companion -> Support zone -> Phone/tablet software update -> Repair my phone/tablet (blue link style). Follow the steps given, do not connect your phone until prompted to press volume down while plugging USB cable.
johanscott
So I did that but nothing works. I hold the volume down button then connect the USB cord to my phone-computer but then my phone just turns on and goes to the charging screen. my phone is fully charged too. my computer wont pick up my phone
John-BR
Hi Johanscott
What I would suggest is some troubleshooting steps for PC Companion. Firstly uninstall it, then make sure that Java is up to date. Then as you reinstall PC Companion temporarily deactivate your antivirus and firewall software as those can sometimes interfere with the installation process. After you have done that please retry the software repair.
Carolina444
I'm having the same issue with my phone and honestly I'm quite pissed off!
I'm currently traveling in Spain and NEED my phone. I have a tablet and tried downloading PC Companion and the file won't open. The resources I have at my disposal are limited....so I would appreciate any help.
I have restarted my phone a few times - pressing the tiny off button... no changes, still stuck with a black screen with "Sony -Xperia".
Thanks,
Carolina
ALDUB
first of all, when updating it will automatically restart itself when finished. you don't want to mess up the update until it is done (via usb or wifi)...so I guess that mistake made your phone damaged.
johanscott
No you misunderstood. I didn't turn it off.
I left it alone once I pressed update and when I came back to it, it was on that black screen (the one that appears when you turn it on) which means that I assume it finished already and it restarted (just like you said). But it was stuck on that same black screen for an hour before I even touched it or anything like that.
johanscott
I had to send mine in to Sony. Couldn't do anything with it.
