Issues in xperia sp
janakaanu
Issues in xperia sp
I recently bought a Xperia sp 4g lte phone and i found lot of issues in it. They are as follows.
1. There is a heat issue when playing games and accesing data.
2. There is lap in rotation view while playing a video. (After the recent update)
3. Extended stand by mode drains my battery 2% for hour in standby mode (NO GPS, NO DATA, NO WI-Fi and with GSM)
I stopped it forcibly and restarted. Some times it works(Drain only 1% for 6 hours), but some times not.
4. Phone freeze for few second when answering to the calls while it is plugged for charging.
5. Adopt to the lightning condition not working at all. This is a big issue when I use my phone in out side. (I can't see the screen text at all)
I love Sony products and I hope you will give solutions for all this with a new update.
5 REPLIES 5
1. That's not an issue its normal
2. Do you mean lag? Could you elaborate?
3. Stamina will take time to learn how you use your phone, keep in mind that there are myriad factors, one of the its network coverage, if its poor it will drain more battery.
4. This might be a bug or it could be the touchscreen issue that  has to be checked at a Sony repair center
5. Do you have an extra screen protector or protective case that might be blocking the light sensor?
Use diagnostics app and check your phone.
Don't forget to give Kudos
Amey
It's kinda like a pause. It pauses the video and resumes again.
does this happen with an specific app?
Amey
Only with the default video player.
janakaanu
1. ok
2. Yes, I mean lag. It pauses the video and resumes again with the default video player.
3. I'm not using stamina mide while I'm not enabling the data. Network coverage is good. Signal strngth -91dBm.
When i force stop extended stand by mood with clearing data and restart. It works fine some times(1% draine for 5-6 hours)
4. No there is no touch issue while unplug. It only happens while charging.
5. Yes i have a screen protector. but it is a clear one. can that be the cause for this issue?
