Greetings,
I have problem with laging bluetooth, when i listen to music through car BT radio, after some time it starts to lag and music stops, my father has a problem with calls, after some time he cant hear the other person, and that other person cant hear my father, his then then starts to lag too. Is there any way to fix that problem, or will be there any update repairing bluetooth?
P.S.: sorry for my English
Could you please elaborate? Which phone model are you using? Have you checked if your phone has the latest software? Have you tried to connect the phone to another Bluetooth device (a headset e.g) to see if you experience the same behaviour?
I took the liberty to change the title and moved the thread to a more relevant board.
It can be due to bad connection, you can always have the phone closer to the car kit to see if it still lags.
Otherwise, it sounds like a compatibility issue which can cause this behaviour. Have you checked with the manufacturer of your car kit to see if they have tried Xperia Z2 with the same software? You can also check with the manufacturer if there are any updates available for your car kit that can help.
Try unpairing your car, restart your device, then pair it again.
