ISSUE IN Z2 after Lollipop Update: Wi-Fi always On
asaswin
I'm using Xperia Z2, and this week I've update it into official Android Lollipop 5.0.2 through PC Companion. However, after the update installed, i seen a horrible WiFi problem: It's "always on". Even after I turn off scanning always available option on Advance Setting, the WiFi still on, as seen from the Battery Usage. This problem makes my Z2's keep awake and taking a huge battery loss. Could you please give me a solution for this problem? Thank you for your answer.
Tags (1)
7 REPLIES 7
profile.country.RO.title
_alexdon_
You cannot disable it? Have you tried to tap on the quick settings icon? Can you check if in safe mode the same occurs?
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
alexdon
asaswin
I've tried to turn it off from quick settings icon, I tapped it to "off" with slash on the Wi-Fi icon, it keeps running as seen from the Battery Usage graph.
Unfortunately, when I turn on the safe mode, the problem was still there. The Wi-Fi is off for a minute. Just as suddenly, it's back on again.
 The Battery Usage Graph shown the phone is awake in the background, even if screen is off and stamina mode on. Thinking_Face
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Kju
@asaswin Please see in Setting -> WiFI -> Advansed Setting - > Always find network (can be called a little differently I use not English locale). Disable this param if You need
a2k22010
It was there even in Kitkat and i have raised this query in the past and it nothing related to Lollipop upgrade
asaswin
@kju: I have uncheck it. Nothing works, the Wi-Fi keeps on.
@A2k: When i'm using Kitkat version, I never found any problem, it was flawless. I'll try to repair the software now.
_alexdon_
Keep us updated.
alexdon
