Have two SSID for 2.4GHz and 5.0GHz. Both worked perferly well on Z ultra x2 and Z3 Tablet Compact. As for Z3, ok for 2.4GHz and can detect 5.0Hz SSID but cannot connect to it. Strange.
cannot connect to 5GHz at safe mode. Thanks.
I have the same problem with my Z3 Dual (D6633).
I have a Netgear WNDR3700 Dual Band Router (award winning).
Beside me I have an Acer Laptop with built-in Dualband connected to 5GHz and also a stationary PC with USB dongle dualband connected to 5 GHz. No difference moving the Z3 close to the router.
I have seperate SSID for 2,4 and 5 GHZ.
Booting into safe mode shows that 5GHz now available, saved and using WPA - but it won't connect. While in safe mode i tried connecting to 2,4 GHz with no problem - but then 5GHZ now shows "Not within reach" - as it does in Normal boot mode.
Apparently when I started up the Z3 for the very first time (2 month ago) I was able to connect to 5Ghz as I have filled in Password and saved this connection.
If this problem appeared before or after the newly firmware update - I cannot tell. I just saw this tread and checked the phone - just to dicover that I was not connected to 5 Ghz as I thougt I was.
Regards
Kim
I did that just before writing previous post.
There's nothing that points a flaw in the router unless the other guy has excatly the same router with same firmware updated.
We'll see if he tell us the brand of his router.
