So i dont know if i had it at start but ive just realized the edge of the top screen is really light when it isnt full screen brightness and im looking on the screen with a side ways. When i look stright at the screen it isnt visible but when i start turning it around it shows. I know you cant help i just want to ask is this normall? Im posing a photo also.
Also 1 more problem. In the dark i see a light through the 3.5mm jack. unfortunately unfortunately its so low that I cant take a pboto of it, it just doesn't apear in any of my photos the light. Its just a tiny bit but is this ok?
I can only replicate what I see on your screen on my z3 by turning the brightness to max but even then it appears on the bottom right of my screen. As for the light leak in the 3.5mm jack. I cannot even at full brightness see any light. sure your not seeing a copper connecter reflecting light?
edit.. Just noticed you were in the dark.
Ok thnx
I was scared that ill have a screen problem
No but i only see it in dark and i see it when the screen is on, no matter if it's at low screen brightness because i still see it. Also Ive letted water in the jack but it isnt leaking inside or anything
I might contact sony later.
