Is acro S waterproof
MVA
hi,
I want to buy an acro S. but i am worry about waterproof feature of this phone. There are some report on waterproof failed on this phone. Is it common in all acro S phone? please help me about this matter.
3 REPLIES 3
Luisguevarach
It depends of your daily care.
A single drop can take away your Acro S "waterproofness" like it would do on other phones.
The secret is to keep all your conection ports close very tight.
I haven't had any problems with my Acro S in terms of waterproof.
I hope this works for you.
Best regards,
Luis Guevara
Alexander1
Xperia acro S is rated IP55 / IP57 according to the International Protection classification system. The first digit in the IP rating (5) indicates that the device is protected against dust. The second digit indicates how well the device is sealed against entry of moisture or liquid. IPX5 indicates that the phone continues to function when directly subjected to 12.5 L of water per minute from all directions using a 6.3 mm inside diameter nozzle at a pressure of 30 kN/m² and a distance of approximately 3m for at least 3 minutes . IPX7 indicates that the phone continues to function and that no water gets inside when the device is dropped in fresh water under up to 1 meter of submersion for a duration of maximum 30 minutes.
The phone is not designed to float or work submerged underwater outside the IP55 or IP57 classification range and should not be exposed to any liquid chemicals.
So to answer the question in a shorter matter. If you don't use the phone outside the IP55 / IP57 classification range it should be protected against water. And as said above, all the ports must be firmly closed to protect against water.
MVA
Thans for your Description about this matter. But i had a motorola Defy before that has IP57. At the first 6 months it was waterproof. after that it lost its property. I want to know is this matter for Acro S too or it will has waterproofness feature all the time.
