I have updated my ARC S software to android 4.1.B.0.431
every thing was ok until some day the Internet didnt work i have checked the ip of my wifi it was a fix ip that i manually inserted before form advance menu under the wifi setting , so i wanted to change it it dosent work any more
i cannot open the tab
i tap the IP section on the advance menu but the window doesent pop up
so i decided to reset to factory default to solve the problem , i did, and the internet was ok as the ip which i had inserted before was erased . but again i cannot open the window for inserting manual IP what should i do?
on the other hand when i reset my phone all the program was erased and when the phone came up i understood there is no file manager app so i cannot access to my SD card in any way to install the program
how can i install this file manager ?
I suggest that you either reinstall the software using SUS or await the .587 update which is being rolled out gradually as we speak.
Your phone model doesn't come with any file manager so I suggest that you download one from Google Play.
