Can we connect Internet connection on PC to WT19i using USB cable ?
As I understand this is not supported by this phone model.
Ya, u can connect ur LWW with pc using usb cable. Need to do is connect your phone to ur pc using usb cable, then go to->SETTINGS->WIRELESS & NETWORKS->TETHERING & PORTABLE DEVICES->(SELECT) USB TETHERING. Thats it u will be connected to ur pc. Before that make sure u have a active data plan.
Hi, if what you want is Reverse Tethering
Surf the Net via USB port with your PC internet use the link below
Reverse Tethering
http://www.codeproject.com/Articles/191930/Android-Usb-Port-Forwarding
Only problem is that you can't download apps.
MeatWare
Thats really disappointing
Thanks for the response but I guess you didnt not understand my question properly. I want the BroadBand on PC to be used in my android device.
Thanks, well the major reason for having the PC internet on my mobile was to download apps from market and by doing all this if I am not gonna be able to download apps then its not helping my cause.
Thanks anyways
does your computer has a wireless card? if it does it will be really easy to share your computer's internet connection
Hi Nesar
I understand your situation because i found this solution to my colleague with same problem.
He don't have wireless in his house and we want to use our connection at work.
Now we will use one wireless pen in Gateway mode to connect via wireless at work.
But the connection only stays up a few minutes because of GB (Android 2.3.4).
When we upgrade to Android 4.0.4 the problem is over.
I have one Kindle Fire (rooted) with ICS and the wireless connection is ok.
MeatWare
It is possible to download from market or even recieve OTA updates with reverse tethering.
Your would need:
-Root access
-Before connecting in reverse tethering, check Data Enabled first until you get Edge/3g/HSDPA signal. This will give u a 3G adress.
-Hit connect in reverse tethering. Voila.
