Hi I bought sony xperia tipo 4 months back and am often facing the problem to connect to the ineternet. Even if I enable the data usage, internet is not connected. Kindly provide suggestion to solve this issue.
Try removing the proxy settings on your APN.
Settings > More.. > Mobile network > Access Point Names
Tap your internet account, usually called "[operator] Internet" or similar. Delete everything under Proxy and (Proxy) port.Save and try again.
Hi I tried the solution u provided but its not working. Suggest some other solution.
