I've been browsing the internet through wifi and the connection is good but when i tried connecting to a non wifi connection like mobile data it won't work. I even loaded my prepaid sim to be able to use the internet through it but still it would always say that i'm not connected. I already enabled the mobile data in the settings but still it won't. Do i still need to change anything?Appreciate your help.xperia z user here.
try this
Settings > xperia > internet settings
Don't forget to give Kudos
Check if you have the correct internet settings...
Go to Settings > More > Mobile networks > Access Point Names ( Call and check your network provider that you have correct settings )
Also low speed connection will also cause this issue
