internal speaker too loud
wojwul
I have a problem with the internal speaker of xperia Z. It is too loud even if set to minimum volume and  xLOUD mode off. When I'm having a conversation - everyone who's within 3-4 meters can quite clearly hear what I hear. None of the system updates solved the problem, neither did the reset to factory settings. On polish android forum there's a thread about this problem, but no solution. Some people are having this problem, the others not.
6 REPLIES 6
Sam
Legend
Legend
That is very strange indeed; I assume you have adjusted the volume down using the volume buttons whilst you have a call connected?
What are your thoughts about this forum? Let us know by doing this short survey.
wojwul
Yes, I have adjusted the volume down during the conversation. It is really strange indeed, I have never had such a problem before with a phone
Sam
Legend
Legend
I assume you have not third party audio modification applications installed? If not then I can really only advise contacting your local Xperia Care team so that the phone may be assessed by an authorised repair agent.
jk100
I have a similar problem. Whne calling/receiving calls the loudspeaker is ALWAYS on full volume... hurting ny ear. Even if I adjust volume during the call, the volume is again on full when the next call comes in. I have NOT found a way to adjust from setting, adjusting from side (vol up vol down) is efective only during the ongoing call. PLEASE PLEASE help.
rajendrasingh
I have the same problem..Volume does not remain low,it automatically turns on full volume on next call.
Please solve this issue.when i turned down volume it should remember my choice.
Scharalambous
I amazing the same issue on the Sony z5. There does not seem to be an a preset option for in call volume. Everytime some one calls I have to manually turn down before answering. I don't know what to do.
