I cannot install appilcation from external usb disk on xperia Z5 problem after update to
Android 6.0 Marshmallow.
It only allow to explore the contents in the externalUSB disk
To install an app from an external USB drive, you first need to enable Settings -> Security -> Unknown sources. Then connect your USB-drive and go to Settings -> Device connection -> USB Connectivity -> Detect USB device.
To install the apk, you then need to download a file manager from Google Play like ES File Explorer where you open the USB drive and tap the apk-file. The native file explorer will not let you do this i'm afraid.
