incoming calls
arhez
incoming calls
When someone is calling me the phone simply vibrates. There is no display of number and no option to receive or disconnect calls
7 REPLIES 7
Thommo
Genius
Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
dandy63
Leader
Hi, could you try....Settings - Apps then swipe right to All then scroll down to InCallUI & select :smileysmileywink:
arhez
@ dandy: it did not help..
@thommo: is there any other solution without help of computers and without losing data..
dandy63
Leader
So, when your phone rings & vibrates is the screen black Thinking_Face You could try running the phone in Safe Mode, this will show if there are any 3rd party apps that could be interferring with your phone functions....link below
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
arhez
Thanks a ton Dandy.. Problem solved.. Grinning_Face
dandy63
Leader
Thats great news......my pleasure Slightly_smiling_Face
ahmedsaleh8484
Dandy... Thanks a lot for your very positive response
I had the same problem & it was solved by selecting the INCallUI... I appreciate your help too much 😄
