i updatedd my lww to ics,at first there was only"obtaining ip"but nothing less,then i removed eset antivirus from laptop,now it connects but the problem is it gets disconnected with connectify wifi after 4 5 mins of using or downloading,i changed password,factory reset,repair my phone,but nothing happened ,it just disconnects then i press the settings ,wifi then reconnects....please tell me what should i do.i tried a lot,is the problem withmy pc or ics,should i downgrade to gb??please
Hmm, since you mention your laptop - are you connecting the phone to the laptops WiFi? Or to a router?
laptop wifi by connectifi.it was all ok while in gingerbread.but probs started after ics update
Ah. You should try connecting the phone directly to the router instead. If that works, there's something in your PC interfering with the connection.
