Hello all
My widgets(not all) after ICS update they look like frozen ,even the stock analog clock , it is updating only when im on the main screen(well maybe its normal donno) ,next, even stock calendar its not showing anything,and after trying again to put it back it will not even show the date ( at the first after UPDATE untill i will restart my phone widgets are working fine ) after restart ,calendar ,weather widget(non stock) are not working for example ,Pure calendar after update works,then restart ,and the widget shows only LOADING ... , stock calendar the same , BeWeatherPro it will show widget but again after restart it just show just the old weather and i cant refresh thruu widget (i can see only actual weather after opening BeWeather) ,Palmary Weather widget just show all the time loading ..
this is a bit annoing ,it was ok on Gingerbread..but not here on ICS
and yes i have made repair thruu PCC and SUS like 3 times allrddy
and its allways the same.
maybe something is causing this problem? ...maybe its 3rd party software...but blocking widgets?hm donno
is it just me or everybody have this problem?
and PS . i like ICS so far ^^
repair your phone with SUS and don't use any taskiller nor antivirus
Update Service (SUS)
hold ur horses Uliwolly
have u even read this post? i said i have repaired thruu SUS like 3 times and its allways the same .
and im not using any taskkillers and antivirus xd
That's why I'd suggested to do it again but this time, do not use any taskillers or antivirus, uninstall mcafee
im not using any task killers ,and antiviruses .
I will try again ,to update ,but not today ,i have done it yesterday .
are you using a thirdparty launcher? RAM app?
Nope , with this apps what i have now everything was working on Gingerbread .
can u try with ur calendar widget(stock one) to re add to desktop? or use analog clock and when u sliding screens wait at the last one for 2 mins then jump back where u have ur analog clock and check hand of a clock if it will jump this 2 mins ,it my case analog clock is frozen when im not on the same screen .
thnx
ok yeah I see it, that's a bug
great im not alone
but u saying about clock or calendar widget?
because with the clock i can live ...but this widgets xd its looks like they lost conection with system and they can not retrieve information . if it is like that can someone pass this thread to devs? thnx
I get the Clock bug
