Hi, I have yesterday updated my SXP manually with the "XDA Rom" central europe, cause ICS was not available on PC-Companion. All works fine during the Update. But i think GB was smoother than ICS. All menus and animations are not soooo smooth like GB, also the scrolling in Opera or another Webbrowser, or the 5 Desktops. All Graphics are slower or not smooth.....
Everyone say here, that the ICS is faster and smoother as GB, should i flash (repair) again ?? When I use now the repair funktion from Companion, will I get GB again, or ICS ??? Should I wait till release ICS here and then repair ???
Actually the not so smootheness of ICS is due to default sony launcher ( not smooth ) , try Nova , Apex launcher from the market and you will feel the difference :smileygrin:
Am i the only with this impression, that GB was faster in the Graphic ?? What can I do to make it faster ?? Does a repair with Companion should solve this Problem ??
you can repair with PCC or SUS and still get ICS i think.
Hi psycho.mantis,
i also felt the same after updating to ICS but after couple of days it's working smooth now.
but yes GB was a bit smoother......
you have to look very hard to see the differance.
The issue isnt with Sony launcher. Maybe you are usign the builtin flwo xperia live wp. try any other wall paper, other than flow, even live WP, and it shld work fine. it does on mine, so i can tell.
