i need help to fix my phone
Hama22
I have Xperia Ion since 2 years ago and just before yesterday while normally using it it rebooted and when the screen turned on again there was triangle with a screwdriver and a blue loading bar i waited and waited and then there was this yellow one i really dont know what to do and pc companion wont detect it plz help me thanx20150815_171702.jpg
3 REPLIES 3
Phy
Legend
Legend
You need to repair the phone with Sony PC Companion.
http://support.sonymobile.com/us/tools/pc-companion/
Phy
Legend
Legend
If you still can't get PC Companion to work try contacting Sony Xperia support.
Thommo
Genius
Performing a system repair using PC Companion - This will factory reset your phone and erase all data
