i have a battery problem
samoeha
i just bought sony p
and i didnt chagre it for 6_8 hours
and now it just run so fast
i can use it for gaming for like 3 hours at top
and android os take alot of my battry
what can i do???
13 REPLIES 13
mithun_xperiap
My friend since its a fair new device it would require say 5- 10 full recharge and discharge cycles to perform upto its full potential. Be patient.
Charge it to 100% check in the battery usage app rather than the % indicator.
Dischgarge it completely then again charge it to 100% without any break. Follow this cycle for 2-3 times and ur device will be fine.
Also charge the device upto 50 %,switch it off and charge it that way till it shows fully charged.
playing games or watching movies/videos/keeping the screen on for prolonged periods of time will drain your battery quite fast, that's normal
also go to
settings > battery > check the graph and the list, tap on the top 3 items, you can take screenshots of all this and post it all here
screenshot: press and hold power and volume down at the same time
restart: press and hold power and volume up for 5-10 secons at the same time
@samoeha do NOT create new threads on the same topic
again it is normal that your battery will last fewer hours if you play games, that's normal
samoeha
and if i use onle facebook whatsapp how much it can last??
samoeha
if i dont cahrge it for 12 hours at the first time what it dose to my battery
some pepole saying the battery last with them for tow days
if your data/wifi is on and you are syncing all the time it will last 8-10hrs, that's normal in an smartphone. the only way your battery can last 1day 2days, etc is if you turn off your data/wifi, gps, lower the brightness and you hardly use the phone.
samoeha
it took half my battery in 2h
that's normal, if you want to avoid that then turn off auto sync (facebook) also wifi will drain quite a bit of battery and as you can see your phone was awake most of the time and wifi on all the time, therefore fb was probably syncing quite a bit, that's normal, if you want your battery life to last longer then turn off auto sync (manual sync only) or set it for every 4 hours
