Hello, I have a problem with my Xperia Ray after the ICS update, now the phone drains a huge amount of battery when its just in standby mode.
And one thing, please create a downgrade tool that lets you downgrade to GB again.
//A very unhappy Sony phone user(Bcuz of the freakin X8)
please explain more , how much battery is depleting when on idle mode ? go to settings > about phone > battery use. and if possible post some screenshots as well of the battery graph.
Hmm, this is what I get in battery graph:
Operatingsystem Android: 40%
Idle: 35%
Cellphone idle: 10%
40% doesn't seems normal to me , i don't have ics installed , will let somebody check if they also have android system consuming this much of battery.
if you don't mind updating again , this should solve the problem.
update your phone with this..
http://www.sonymobile.com/global-en/tools/update-service
this is an official sony software so don't worry..
and if it says your phone is up-to-date click on install anyway..
this will delete all the phone's data so backup all your files first..
Already done a SUS update, doesnt solve the problem at all
Something is wrong with my username, I cant see it:P
lets focus on the phone problem's first :smileygrin:
have you downloaded any application which might be interfering with the battery ? anything like task killer ot battery saver ? if you use it , uninstall it , if not then
go to settings > privacy > factory data reset. after doing this update your phone again
i know its a long procedure but give it a shot.
Regarding battery,
Format your sd card and again reinstall your phone's software using pc companion......
see how it goes... otherwise i think you will have to downgrade to GB
Already done that, and I have tried to "repair" using SUS, but It doesnt help
My sdcard is clean, no folders or anything on it.
Formatted it, but it doesnt help at all
i know , but just do a factory data reset before updating. this may solve the problem.
