I need help about rooting phone as i want to use applications that require rooting.
I used DoomLord, Flashtool and superoneclick but i could not get my phone rooted.
There is some kind of read write error.
Is it necessary to unlock bootloader to root the phone?
U cannot root ICS directly. U have to downgrade to GB, then root and upgrade to ICS again.
Here's the link -- - -- http://forum.xda-developers.com/showthread.php?t=1695514
I have downgraded to gingerbread but still same as above
which GB build number? is it .42?
It is .62
and tell me wether i need to unlock bootloader to install custom roms such as Cm9 ,MIUI etc....
you can't root .62, you need .42 and then user SuperOneClick
after i flashed .42 and then i will update to ics,will my phone remein rooted or not?
the thread above is about jellybean
if you update OTA it should remain rooted
